Seized Engine
Old 08-28-2015, 04:07 PM
Philhawtin's Avatar
Default Seized Engine
So I posted a few days ago about there being a hole on top of the tranny where a bolt could fall down into. The reason I asked this is because I was recently doing some work with the intake manifold off. Now before you say anything, I am 100% positive nothing went into the cylinders via the valve openings.
However, The only thing that did for sure enter the cylinders with opened cs was some starting fluid (I sprayed to get a little bit of dirt off one of the valves)
So hydro-lock is a possibility, I just don't know how likely.
As for that pesky bolt I dropped... I actually lost 2 bolts behind the engine/above the tranny. I just don't see where it could have entered the bell-housing and jammed up the flywheel???
Also when I put a breaker bar on the crank it does not move one way or the other AT ALL.
Im hoping someone out there has a golden nugget they could throw my way.
If not, Im going to start today by pulling the alternator 1st ( thats gonna be a tough job) and after that Ill be slowly pulling that tranny back, and if not still. I will have to pull that flywheel.
ANY help would be massively appreciated.
thanks
Phil
Old 08-28-2015, 04:32 PM
SloopJohnB@mac.com's Avatar
Default have you tried the borescope/endoscope?
thanks
Phil
Hydrolock is unlikely, especially if you pull all the plugs.
Old 08-28-2015, 04:56 PM
tenspeed's Avatar
X2 - loosen the plugs a couple of turns to eliminate the possibility and allow air to escape on the compression stroke when turning the engine over by hand
Old 08-28-2015, 05:00 PM
Philhawtin's Avatar
I apologize. I have the manifold back off, the injectors out and plugs out. Still stuck as a stoner.
Old 08-28-2015, 05:25 PM
Default I doubt if the engine is seized…jammed probably.
I would try to turn it backwards using a pry bar at the flex plate from underneath. Turning it backwards at the crank bolt will just back it out.
Removing the starter before you take out the transmission seems like a better idea than removing the transmission. Remember with an automatic you have to support the transmission then remove the TC bolts to the flex plate. If you can't turn the flexplate/engine, you'll have a much worse time pulling the transmission out and leaving the TC attached to the flex plate. Even then you'll have to unbolt the TC from the flex plate which may be very difficult.
Old 09-02-2015, 05:03 AM
Airbag's Avatar
okay stupid question .. have you tried fishing down that hole in the top of the bell housing with a magnet or a borescope ? I realize if there is a bolt down there it may be jammed but If you could see ift down there with a borescope it may help.
Old 09-02-2015, 05:18 PM
the_duke's Avatar
CrazyFire® 2.0MP HD 720P Coms 6 LEDs USB Snake Inspection Camera Waterproof Borescope Snake Digital USB Video Camera Pipe Locator: Amazon.com: Industrial & Scientific CrazyFire® 2.0MP HD 720P Coms 6 LEDs USB Snake Inspection Camera Waterproof Borescope Snake Digital USB Video Camera Pipe Locator: Amazon.com: Industrial & Scientific
Mark VII
14
09-26-2023 10:11 AM
myroad
Audi A3 / S3 / RS 3 MKII
10
09-17-2015 06:41 PM
Florida8L
09-07-2015 05:51 AM
giuseppepat
09-02-2015 02:47 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
Quick Reply: Seized Engine
