Sponsored by:
Sponsored by:
Airbag Light Problem Solved
Old 04-18-2015, 03:38 PM
  #21
mishar's Avatar
Originally Posted by trustzzz
Sorry brought this old thread back, would you please tell me how to do that ?
do I need to remove the steering wheel ? or just remove the steering wheel under panel ? because my steering angle sensor get the power on and off so I may need to check the connectors/connections. whats the connector looks like ? some detail info please. please help !
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 22128 000 00000
VCID: 224BDF77FD70713158B-8077
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
At the end I replaced my Steering Angle Sensor. You may try to clean contacts but that was not lasting solution for me.
To get to the sensor (connector) you need to remove the steering wheel, including airbag. Not too difficult but be careful.
Old 04-18-2015, 04:02 PM
  #22
trustzzz's Avatar
Thanks, and I just found is from Ross-Tech WiKi:
Possible Symptoms
## Malfunction Indicator Light (MIL) active
Possible Causes
## Temporary Supply Voltage Interruption
## Steering Angle Sensor (G85) faulty
## Steering Column Control Module (J527) faulty
Possible Solutions
## Perform Steering Angle Sensor (G85) Adaptation ## See Vehicle specific Diagnostic Procedures for Details
## Check/Replace Steering Angle Sensor (G85)
## Check/Replace Steering Column Control Module (J527)
So how do you determine is the steering Angle Sensor or the Steering Column Control Module ??
Old 04-18-2015, 06:46 PM
  #23
mishar's Avatar
8E0953541E steering angle sensor.
Scan doesn't say anything about Column Module, so I believe it is sensor.
Old 04-18-2015, 08:03 PM
  #24
trustzzz's Avatar
Thanks a lot !! I like to make sure before I spend almost $400 to get it.
So my ESP lights( triangle warning lights) will be on and off when I was driving, usually if I go straight the lights won't go off, but once I turn left or right the lights will go off and after I go straight for a few seconds the lights will be gone. Is that what happen to you too ?? i
Old 04-18-2015, 10:46 PM
  #25
mishar's Avatar
Not the same symptoms. But Art is unpredictable.
Old 09-19-2018, 06:17 AM
  #26
inchung Lee's Avatar
Default thankyou
oh god. my 2007 a8l d3 warn me a airbag light. i do vcds and clear the default code but it appear within 2seconds. i removed the seat bench. and find yellow connector. so i disconnect and connect it again. but it still does not work. tomoorow i will do this wd40 technik h h . thankyou
Old 09-19-2018, 03:16 PM
  #27
TSHong's Avatar
If you can find this,
Amazon Amazon
, it will most likely cure the issue and never have to touch it again.
Old 09-19-2018, 04:45 PM
  #28
Default oh it does not work. . shall i do clear code again?
i did sprayed the yellow and red connector with disconnected. but the airbag warning did not disappear. do i clear the default code with vcds again??
Old 09-19-2018, 11:29 PM
  #29
TSHong's Avatar
yes, clear the code after you clean the contact.
Old 09-23-2018, 05:12 PM
  #30
Mister Bally's Avatar
And if cleaning the rear side airbag contacts does not do it, that airbag igniter (assembly) probably needs to be replaced to properly keep the airbag malfunction indicator off.
Of course, you need to perform standard automotive electrical/electronic system troubleshooting techniques. There are additional important precautions required for Airbag systems that need to be adhered to. BE SURE TO FOLLOW THE STEPS IN THE PROPER SERVICE MANUAL FOR YOUR VEHICLE. You can be injured or killed by an airbag that deploys while you are servicing the car.
The connector on the airbag control module could be corroded. There could be a broken wire in the harness.
Personally, I would leave airbag servicing to a dealer but that is just me. My daughter's Jeep airbag light came on two weeks ago. The service manual said dealer system troubleshooting only. I had a dealer repair it (Bad clock spring $$) I want everything properly done for my daughter's ride.
Jon-1.8t
01-16-2006 06:38 AM
LenVOS8
VAG-COM Discussion
12-08-2005 06:37 PM
dhjorth
09-14-2005 05:05 PM
Psssss
VAG-COM Discussion
03-12-2004 05:41 PM
Wayzatajim
04-15-2003 10:14 AM
Quick Reply: Airbag Light Problem Solved
