Help with Leveling Suspension
#11
You cannot guess at the compressors health by simply looking at measuring blocks.
In order to test the compressor you need to run an accumulator charge test as mentioned in the following thread
Once you start the test it will start the compressor charging the accumulator (air tank) but it will time out after a short time, you must repeat the test three or four times to get up to 16 bar, if you find that it won't go past say 12 bar don't keep re running the test as you will over heat the compressor.
http://forums.ross-tech.com/showthread.php?1996-Level-Control-Bleeding-Charging&highlight=Charging+bleeding
#13
Ran test
First of all thanks everyone for all your help. I ran this test only once and here are the results. Any suggestions?
- Charging -
[Select]
[34-Level Control]
[Login-11]
[08367]
[Do it!]
[Basic Settings-04]
Enter:
Group [023] = to Charge Pressure Accumulator Field 4 = 14.97
Group [024] = to Charge Front Axle Field 4 = 8.14 bar
Group [025] = to Charge Rear Axle Field 4 = 6.18 bar
Field-[4] will display the current pressure
Note: System will time out after 60 seconds, the procedure maybe repeated as necessary to achieve the desired system pressure.
- Charging -
[Select]
[34-Level Control]
[Login-11]
[08367]
[Do it!]
[Basic Settings-04]
Enter:
#16
Will Perdue
16
04-28-2014 03:06 AM
AudiForYou's 2.7T
Audi allroad
02-20-2005 05:40 AM
