RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
Startup after 2 years standstill?
Old 11-30-2015, 09:57 AM
CSA
CSA's Avatar
Default Startup after 2 years standstill?
Hi Guys
I need to startup the car after 2 years standstill in heated, dry garage. Had the oilcap off and if´t looks good down there. However the cams are dry from oil so I'd like to crank the engine to get oil pressure before starting it. Question is: is there a fuse or plug I could pull that will make it turn over without starting, and without drowning the cylinders i unburned fuel?
Old 12-03-2015, 12:47 PM
AudiWorld Expert
Reggie's Avatar
Originally Posted by CSA
Hi Guys
I would look at the fuse box - Don't have my car anymore but I am sure you can find one that controls the ecu.
If you can I would put oil into each cylinder through removing the spark plugs. If fact pull the plugs and let the engine rotate so there is no compression.
digimurda
20
01-17-2018 03:57 AM
hitrun222
05-15-2012 06:44 PM
MtnA4Quattro
12-29-2008 12:37 PM
smwilkins
11-21-2002 07:32 PM
mike90q
08-30-2001 03:46 AM
Quick Reply: Startup after 2 years standstill?
