Ramps that fit the s4 ?
I'm not having much luck with the search, I guess "ramps" point to the sports diff a lot...
I moved and lost my lift, so now I have to slum it with ramps... Rhino ramps are cheap but I'm not sure they'll take the S4's low front end. Low profile race ramps are like $200 (which is a bit step for a piece of molded plastic). Can anyone confirm a decent ramp that'll let an S4 climb with the spoiler still attached ? Thanks !
Unless you are lowered rhino ramps work fine for stock suspension.
I own the 12K LB Rhino Ramps...used them with an old '87 Porsche 924S that I'm pretty sure has a lower approach angle than my '13 S4. The approach was close, but worked. You can always lay a couple pieces of approach wood (1-2" in height) in front of the ramps to give the front end a bit of clearance.
MonSoonHell
09-15-2015 07:14 PM
bilbo6209
09-09-2015 01:28 PM
