19mm Neuspeed rear sway bar install on Avant
Last Sunday I installed the Neuspeed RSB (thanks Brian) on my Avant. The bar was sold as 22mm, but with crude measuring, I'm confident it's in fact 19mm with the upgraded sub-frame reinforcement brackets.
All went well as you can see by the photos:
But I have a few concerns (yes I searched and spent hours reading every RSB post available):
I lubed the bushings well with marine grease as expected. I noticed that after all was installed, I could shift the bar slightly back n forth in the bushings. The bar has no welded in stops like some of the Neuspeed units I've seen and the ploy bushings don't grab the bar tightly.
Is this because of all the grease I used? Is it supposed to do this? Does your RSB do this?
2nd issue:
After lowering the car back to the ground, I can't even get my pinkie (flat way) to fit between the end-links/uprights and the rear axles. I've been driving it this way for about 3 days w/ one run up/down a twisty back road. I crawled under and could not see that there are any signs of them actually rubbing/damaging anything.
Is this because I'm lowered that I have to be concerned about this clearance? Do stock height PPL have this problem? I know the solution is metal end-links, but I only paid two bills for the bar shipped and I'm not excited about dropping another $47 each on links.
Any comments on this?
I know of another solution that has been tried with success and posted before:
http://www.robsaudiworld.com/neuspeed.htm
This document shows 1/4 inch spacers can be placed behind the bushings to provide more clearance. Scroll down.
So I made up some aluminum spacers today, but have not installed them yet.
Q: Do you think I have enough clearance without them, or have I just not done enough spirited driving yet that I'm detecting a problem?
Anyone else have this RSB kit and how much space do you have between up-links and axles?
Any input appreciated - sorry so long. Thanks! []
2nd issue:
link: http://www.audizine.com/forum/showthread.php?t=259054
DIY Video
Awesome post - If anyone is still using this thread, here's a DIY video of the installation of the 034 sway bar and end links!
https://www.youtube.com/watch?v=sFUW...ature=youtu.be
troyegly
07-22-2004 04:25 AM
mooman
02-06-2002 07:09 AM
S4er
12
10-20-2001 06:31 AM
808Guy
06-27-2001 01:39 PM
