Front Brakes
Front Brakes
stock 01.5 s4 avant
I was driving a great mountain road the other day and was having a great time until I came to a steep downhill straightaway. A school bus was unloading and I had to get on the stock binders pretty hard and then... they started fading... and fast! Scared me a bit.
I need to replace the pads and rotors anyway so what is my best value? I really don't want to spend a lot of money $300 - $600.
These any good?
http://www.blauparts.com/proddetail.asp?prod=D2B2116-B
Are these stage 2's worth the extra money?
http://www.ecodetuning.com/shop/cart...t_detail&p=309
or is there anything better???(for the money)
These any good?
I would go ahead and get the kit - I doubt your pads and rotors are really the issue - unless you are making metal to metal contact your braking capacity is not going to fade out quickly just because the pads are old. You probably need to get a higher quality pad to handle the hard braking and do a thorough flush, refill and bleed of the brake fluid.
Former Vendor
These any good?
To get better performance from brakes you need better pads and fluid.
Stick with plain face rotors, Zimmermann, ATE, Balo are all genuine German made and high quality components.
For pads, go with something with a higher operating temp than OE. PBR Ceramics, Hawk HPS, just to name a couple..
Fluid, go with a good high quality DOT4 like ATE Super Gold, or Motul DOT5.1, both are excellent street fluids.
We've got a couple good options available, visit our site, or email me if you have questions.
That's just an OE replacement kit. Not much more performance than stock. Don't let the rotors fool you, going with a slotted rotor really isn't going to give you any difference on the street.
My guess is that the main factor in braking power is the size of the rotors and the pad material.
N'Syncro
33
02-16-2020 03:12 PM
bazookatooth
09-12-2015 07:18 AM
