VAG-COM Discussion
Sponsored by:
Sponsored by:
New Bose Amp or Control Module???
Old 10-14-2013, 06:58 AM
edgeq7's Avatar
Default New Bose Amp or Control Module???
Received the following on my 2007 Audi Q7. I was able to determine all codes except for the ones dealing with the sound system and associated control module. Trying to determine if I need a new amp or if the control module/bus needs to be replace. On the Ross Tech site there is no break out for the error code I am receiving. All MMI functions work with the exception of no sound and loss of b/U camera picture, but there is no fault indicated in B/U camera address in the read out. Any info would be appreciated
Thanks!!
Friday,11,October,2013,17:16:30:55389
VCDS Version: Release 11.11.6
Data version: 20121223
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 37 3C 42 46 47 4F
52 55 56 61 62 65 67 69 6C 6F 72 76 77
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Sporadic communication error 1000
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 906 032 BG HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G 1634
Revision: 5CH05--- Serial number:
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 68D4A3B15BAB865888B
1 Fault Found:
001072 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 267760 km
Time Indication: 0
Date: 2013.10.10
Time: 16:37:04
Freeze Frame:
RPM: 2437 /min
Load: 40.4 %
Speed: 83.0 km/h
Temperature: 85.0°C
Temperature: 20.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.351 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No SW: 4L0 910 156 C HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0010
Revision: --H01--- Serial number: 4009439
Coding: 0000002
VCID: 2952E6B580217F50575
No fault code found.
Address 03: ABS Brakes Labels: 4L0-910-517.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0033809
VCID: 2854E3B19B2B465848B
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100606243
Coding: 0000135
VCID: E3CE349D228D6500DD9
Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 731 P HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 354KU067514804
Coding: 0002003
VCID: 356A3AC55C992BB0C3D
Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
1 Fault Found:
02849 - Control Module for Lane Change Assistance (J769)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 37
Mileage: 266894 km
Time Indication: 0
Date: 2013.09.29
Time: 18:09:52
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000000087246
Coding: 0524326
VCID: E1C23E9538917710CF5
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0014103
Shop #: WSC 09417 444 85746
VCID: 31620ED5A8F107909F5
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 09417
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 09417
3 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 55
Mileage: 262136 km
Time Indication: 0
Date: 2013.10.09
Time: 16:26:00
01024 - Rain Sensor (G213)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 55
Mileage: 262136 km
Time Indication: 0
Date: 2013.10.09
Time: 16:26:00
01494 - Bulb for Parking Lamps; Left (M1)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 2
Fault Frequency: 1
Reset counter: 37
Mileage: 262136 km
Time Indication: 0
Date: 2013.09.29
Time: 18:20:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 A HW: 4L0 035 110
Component: MP3-Changer H43 0350
Revision: 00043000 Serial number: AUZ5ZBF1021237
Shop #: WSC 00000 000 00000
VCID: 1D3AC265C46993F02BD
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0019000
VCID: 2C5C1FA18FD36A78AC3
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD04530J
Coding: 0014131
VCID: 2B5E1CBD8ADD6D40A59
Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026063010203
Coding: 0002042
VCID: E6C82D89D1BF10283A7
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H17 0170
Revision: 00700000 Serial number: 5HH736YC6
Coding: 2577268
Shop #: WSC 48940 000 1048576
VCID: 234EF49DE20DA5001D9
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06B08814F
Coding: F757DE77747A02
VCID: ECDC5FA1CF532A786C3
2 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 20
Mileage: 267698 km
Time Indication: 0
Date: 2013.10.10
Time: 07:12:09
02077 - Media Player Position 2 (R119)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 58
Mileage: 267792 km
Time Indication: 0
Date: 2013.10.11
Time: 07:00:21
Address 1E: Media Player 2 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H09 0700
Revision: 00000000
VCID: 2756E08D56354920411
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 L
Component: MNS US H48 1100
Revision: 00000000 Serial number: 313KR067513366
VCID: 387433F14B8BD6D8D8B
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH07 0070
Revision: 00H07000 Serial number: 6PZ 009 014-00
Coding: 0010001
VCID: 2D5A12A5B4C96370BBD
Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H06 0070
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: €x
Coding: 0051787
VCID: 2F6608ADBEC51160891
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01025953620000
Coding: 4487197
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000060899
Coding: 0012001
VCID: DEB8056909EF48E8F27
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00000000 Serial number: hR#
Coding: 0051787
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000007
VCID: 3D7A22E564A9F3F00BD
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388KW067574100
Coding: 0000002
VCID: 2E5815A9B9CF1868827
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000063997
Shop #: WSC 09401 444 85882
VCID: E4CC378127836238243
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 0123456789
Coding: 344630393135313035442056413030313233343536373839
Shop #: WSC 09417 444 100634
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 37
Mileage: 1048575 km
Time Indication: 0
Date: 2013.09.29
Time: 18:01:24
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900036810
Coding: 0062424
VCID: 2240F199FD17AC0816F
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000611200146
Shop #: WSC 12336 024 394758
VCID: 346C07C157E332B8F43
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
Coding: 0000002
VCID: 244CF781E703A238643
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6Y40ER
Coding: 1000101
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 001337471-----
Coding: 0003595
VCID: 2648ED89913F50287A7
Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Component: J_394_EE15_SKB09H10 0180
Component: J_392_EE15_SKB09H10 0180
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220631906469
Coding: 0231246
VCID: 2756E08D96354920411
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007555578
Coding: 0010900
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 07: DTCs cleared
Control Module Part Number: 4L0 910 468 HW: 4L0 907 468 A
Component and/or Version: J533__Gateway H06 0040
Software Coding: F757DE77747A02
Work Shop Code: WSC 31414 790 00001
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 20
Mileage: 267698 km
Time Indication: 0
Date: 2013.10.10
Time: 07:12:09
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 58
Mileage: 267792 km
Time Indication: 0
Date: 2013.10.11
Time: 07:00:21
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 20
Mileage: 267698 km
Time Indication: 0
Date: 2013.10.10
Time: 07:12:09
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 58
Mileage: 267792 km
Time Indication: 0
Date: 2013.10.11
Time: 07:00:21
Address 19: DTCs cleared
Address 09: DTCs cleared
Address 76: DTCs cleared
Optical Bus Diagnostic : 3dB Attenuation
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
0E-Media Player 1 OK OK
1E-Media Player 2 OK OK
77-Telephone OK OK
47-Sound System ERROR ERROR
67-Voice Control OK OK
56-Radio OK OK
37-Navigation OK OK
0F-Digital Radio(SAT) OK OK
Old 12-20-2013, 04:16 AM
life4sk8's Avatar
Hi, I know it si an old thread but did You find what sas the issue With your sound system? I have the same problem With m'y A6.
Old 12-20-2013, 04:58 AM
edgeq7's Avatar
Yes it was the amp water damage. Got amp on line $400. Had to use dealer for install as they had to do some coding. ~240 for labor.
Old 12-31-2013, 03:21 PM
life4sk8's Avatar
Ok thanks... You bought it on ebay???
iestatic
S4 (B8 Platform) Discussion
20
07-15-2022 09:43 PM
xkahn
02-08-2018 10:43 AM
Aman Singh Parhar
11-29-2016 05:03 AM
mdkv5
A6 (C7 Platform) Discussion
09-16-2015 01:09 AM
2006A8LW12
09-12-2015 05:02 AM
Quick Reply: New Bose Amp or Control Module???
