Just got my HEX-COM :) One question for airbags...
<center><img src="http://pictureposter.audiworld.com/47676/xenon.jpg"></center><p>I just got my HEX-COM!
I already used it to reset the code for my Xenon lights that was showing up. Stopped the car and started it back and everything seems ok now!
The question now, is there a way to make a diagnostic if I have my "crash sensor" on the front using the VAG? Like, if I look in the "Air bags fault codes", should I see if there's something abnormal with a crash sensor missing there?
Thanx,
Sylvain
Thanx,
Sylvain
I would assume so.
However, since I did not write the firmware running inside your Airbag Controller, I cannot tell you with with absolute certainty what faults it will or will not report.
What I can tell you with certainty is that if your Airbag Controller reports a fault, VAG-COM will show it to you..:-)
-Uwe-
-Uwe-
http://www.Ross-Tech.com
If I knew where the crash sensor was, I could check physically because (m)
If I knew where the crash sensor was, I could check physically because if I have a accident, I would appreciate if the crash-sensor detects it and would like the airbag to be deployed and the doors unlocked...
audiinnj
A4 (B8 Platform) Discussion
9
12-05-2018 04:31 AM
mug23
09-27-2015 10:28 AM
bilbo6209
09-09-2015 01:28 PM
