Engine Sludge
Do it yourself for another $500 probably in gaskets and fluids and bolts, or another $5,000 for dealer to do it.
I bought the Autorx for $65 for three tiny bottles, I hope it is the real deal.
If you cn document religious maintenance VW might come through but you have hi miles good luck
Knocking is rods getting ready to split or bend or just poke out side of block. Once you have knock you are in trouble.
Tapping is less fatal but no fun.
If it goes away when temp/oil pressure comes up, stop, tow it, and lock the key away until its fixed, you might get away with pump/pickup repair. and be OK.
Or call click and clack the MIT tappet brothers. HAHA wheeze.
It works like this
buy a few bottles
Buy a BIG oil filter for your Audi/VW
Put on the filter (as long as there is enough miles left for the oil)
Dump a bottles worth into your oil
Drive (3000 miles)
Dump the oil and filter and add a oil like Rotella T and another big filter (germanfilters.com cheap as all s#%t)
Drive more miles
Dump the oil and filter replace with Mobil 1 or if it still looks crappy inside do the above again like I did.
Drive some more miles, if it looks clean change to Mobil 1 (0-40)
Sludge gone, drop the recommended dose of maintenace Auto RX in and keeps your engine clean
Saves a new engine, you heaps of bucks and you are a happy camper
Dump the oil and replace with
