Oil caked piston rings...!!
Well, was having a HARD miss on cyl6 accompanied by oil immediate oil soaking of the spark plug I thought it would be the rings. Ripped it down only to find the two cylinders I was having compression issues on, the oil rings and the 4 oil "channels" behind the rings completely clogged, well 1,2 or three on each of cyl 3 & 6.
What do you guys think? Worth rebuilding (rings, bearings, etc..) And of course while its apart I will be blueprinting. Getting everything clean in the make shift parts washer. Lots to follow..
Im quite sure I had the first post in this forum!
Im back baby!
But seriously, think this is bad? Should I just get a used long block and get back on the road...
Im back baby!
Im back baby!
Im back baby!
So far, so good. Ive only mic'd the upper portion of the block so far. Tonight I will get the crank out and get the "true" bottom measurements and well see. I think shes in good shape.
Raleigh, N.C. Area! Id love anything you have! Id really loke to sleeve a block for HC and do a custom turbo build. Could only do it if I had a donor motor though. My fiance is dying for her car back! LOL
All 6 are out!
You're rolling the dice on a used engine. I'd rebuild if I were you. I have a bunch of parts you can have if you need anything - including an extra block that is taking up space here. Where are you located?
All 6 are out!
I'm in Cincinnati. The block is yours if you want it.
My cabriolet suffered a loss of oil pressure and the bearings were all shot. The heads got eaten up a little bit too.
Pistons, rods etc are all fine as far as I can tell.
It's an AAH but i think the blocks are the same AAH to AFC
Snuckley
A4 (B8 Platform) Discussion
05-05-2012 10:14 AM
JWG
12v V6 Discussion
11
01-08-2005 03:59 PM
