Just bought a leak tester, guess what I am doing tomorrow........
I used the parts list from AWE. Total was about $8.00
Wednesday,13,August,2008,16:54:25:36472
VCDS Version: Release 805.0
Address 01: Engine
Control Module Part Number: 8D0 907 551 L
Component and/or Version: 2.7l V6/5VT G 0001
Software Coding: 06751
Work Shop Code: WSC 00000
3 Faults Found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-00 - -
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 01: Engine
3 Faults Found:
P1555 - 35-00 - -
I am having an issue similar to Kanahootie in the post above........
but I think I have a kinked N75 line. I put a manual boost controller on several months ago and that is when my problem started. Seems to happen more frequently now.
I had it running parallel to the N75, just capping spikes. More..
It was leasked air constantly. The check ball inside wasn't seating. Even if I turned it all the way in. It was still catching the spikes at 20-21 where I had it set. Everything was ok if you either babied it, or had it wide open. If I tried to drive half throttle it would throw me into limp mode for a bit. (Maybe the MBC was just stuck open?)
Anyway, I am going to leave it off. I am on 93 now and the extra 2-3 psi is nice.
Bender11
05-06-2008 08:41 AM
Tgr_Clw
48
10-19-2007 04:26 PM
Gldnrkt(GT3076R)
09-11-2006 04:30 AM
