Vibration under power
Old Jan 25, 2011 | 06:43 AM
jrmcm's Avatar
Default Vibration under power
I'm gonna cross post this message in the B6 S4 forum as well...
I'm having a very noticeable rapid vibration when under engine power. This occurs while moving or stopped, in gear or not (B6 S4). It's felt everywhere in the car (seat of the pants, shift lever, steering wheel). When under power while moving I can feel it, dropping it out of gear (and thus to idle) makes it completely go away, or I can feel it while sitting stationary and revving the engine. I'm also noticing a change in exhaust sound (aftermarket, Borla). Any thoughts on this?
Old Jan 25, 2011 | 08:37 AM
mishar's Avatar
Tech Guru
Sounds like misfiring.
Old Jan 25, 2011 | 10:51 AM
jrmcm's Avatar
If that were the case, I would think it would vibrate at idle as well. Yet it doesn't.
Old Jan 27, 2011 | 07:44 AM
2005AUDIS4's Avatar
also, i'm pretty sure that you would get the check engine light if it were misfiring. any lights or codes to speak of?
Old Jan 27, 2011 | 08:04 AM
mishar's Avatar
Tech Guru
Not necessarily. Bed spark plug can still manage to fire on idle and loose it under load. I believe it won’t trigger any warning.
Old Oct 9, 2011 | 05:06 AM
AusA8's Avatar
Was there any resolution to this issue?
I think I may have the same issue...
Old Nov 10, 2011 | 07:57 PM
doylfish's Avatar
probably coil packs or plugs..i got horrible vibration under power and a CEL when my coilpacks went
JevansS4
Sep 28, 2016 01:53 PM
MNAudiA6
A6 (C7 Platform) Discussion
20
Jan 4, 2016 07:25 AM
jrmcm
May 29, 2011 09:54 AM
SPhwoarr
Nov 4, 2009 01:01 PM
DavidFeygin
10
May 19, 2003 03:51 AM
