AC problem
Old Dec 27, 2012 | 02:28 PM
xxvarcxx's Avatar
Default AC problem
How's it going guys. My AC stopped working recently so I pulled the codes 22.1 and 5.3. Before deciding to replace both the ambient temperature sensor and the high pressure switch I took a look at them, but saw that the wire loom that contained both the ambient sensor and high pressure switch wiring had been eaten up by a pulley. The ambient temperature sensor was completely ripped off. Well now I replaced all the wires and I still have hot air blowing and the codes are still there. Do the codes re set themselves? Or is there anything else I can do?
Old Dec 28, 2012 | 06:42 AM
tommyleea's Avatar
It sounds like you still have the problem, so the codes are still there. Is you compressor kicking on? Or, take a look at the other post about the pressure switch.
Old Dec 28, 2012 | 07:49 AM
xxvarcxx's Avatar
Thank you very much. I read the other post about the pressure switch. I will be going to autozone today to purchase it. The outside temperature is being read perfectly it matches the outside temperature. I'll troubleshoot the compressor today and report back. Thank you for your help.
Old Jan 9, 2013 | 05:30 PM
xxvarcxx's Avatar
Sorry to have taken long to reply back. I replaced the high pressure switch and I am still getting the 22.1 code. I did notice that when I removed the old switch the Schrader valve was hissing.
Old Jan 9, 2013 | 06:22 PM
tommyleea's Avatar
Is the air working now? If not, is the compressor kicking on?
The shrader shouldn't hiss once the switch is removed. It is either loose, or the shrader is bad, and it will continue to leak, and deplete your freon.
Old Oct 7, 2017 | 05:29 PM
Angelbabytk1!'s Avatar
I took my Audi into this new Audi service and they said the shrader valve was loose. I had this car in the service at another Audi service off and on for a year for it blowing hot air and they couldn't figure it out. The other day i heard a pop from the engine, I thought it was the ac that kicked on.
Now tonight my engine light came on, Anyone else has had this issue?
Q5Boostin
Q5/SQ5 MKI (8R) Discussion
Jul 10, 2017 02:02 PM
audi1031
Jul 17, 2010 05:24 AM
ado_dado83
Mar 23, 2007 08:01 AM
MM120
12v V6 Discussion
May 12, 2004 10:50 AM
Crayfish
Quattro: Turbo / Ur / Sport
15
Feb 19, 2003 11:02 AM
