anyone know how to remove steering wheel on 1998.5?
replacing headlight switch, wheel seems different than what i am used to. has a t55 torx hole right in the middle once the airbag is off...
unplug the battery and let it sit for 10-15 mins first...
then take off the air-bag, with two (sport steering wheel) torx (T25) and then get a 24mm socket wrench and remove the big bolt that holds the wheel on.
No, the 98.5 is difference with 96. The 98.5 had the bolt instead of nut. 12-point torx type.......
That what hold me backI have a sport steering wheel in garage and can not replace it because I do not have the right torx
alright, finished, thanks guys. here is the correct info...
2 T30 torx to remove the airbag, and the 1998.5 had a bolt, a very big one, with a T55 and a ton of torque to remove. Dont forget to mark it with a marker to sit it right when replacing. After that, a 4mm allen screw loosens the clamp for the switches. unplug all harnesses (left and right) and slide switches off. 20 minute job.
davenew
22
12-31-2006 05:33 AM
AEGA4
05-21-2003 04:07 PM
dparnas
03-09-2003 08:59 AM
®StanG®
09-03-2002 08:49 PM
