Brake Pad Question.....
AudiWorld Expert
I am planning on changing the pads all the way around this weekend. I have about 5,000 miles on these rotors(Audi Stock). Do I need to have them resurfaced? If yes, who could do the re-surface?
Are there any other things I should look for? Tips, hints?
TIA
TIA
The rear can be a PITA due to the parking brake mechanism.....
....you need to push and turn the piston to get it to retract. You <i>may</i> need to use a special tool to do this, I did.
<img src="http://pictureposter.audiworld.com/116/A4_Brake_Piston_Tool.jpg">
A combination of using his tool to push and turn, along with a few squeezes from a C-Clamp allowed me to get the rear pistons to retract. I tried the needle-nose plier method which was mentioned in the FAQ, but all I ended up with was bloody knuckles.
AudiWorld Expert
I saw a tool for brake pistons at either Pepboys or Sears...would that work?
It looked nothing like the one in the pic though...I am gonna have to go back there and check it out.
As long as the tool allows you to turn the piston as well as apply pressure......
....it should be fine.
There is a much nicer tool available from Baum tools:
<img src="http://www.baumtools.com/products/3131.gif">
<b><i>3131 - BRAKE CALIPER SPANNER
Priced at only $25.53</i></b>
I doubt you'll find it at PepBoys though. BTW, I bought my Lisle "cube" tool at PepBoys.
Former Vendor
Resurface...
I'd recommend a resurface whenever you change to new pads. You run the risk of the new pads not setting correctly, and thus squeeling soon thereafter. Most brake shops will resurface your rotors for a minimal cost. You could also find a local machine shop to do the work.
I've seen a couple of those brake tools used for the rear piston on Ebay, around $20.
jquattro
10
10-13-2002 07:13 PM
RobC
07-29-2002 07:39 PM
OneTurboSomeDay
09-05-2001 07:07 AM
