Car stalled
Car stalled
Yesterday I was sitting at a stop light (on a hill, but I don't think this matters--brake applied). While waiting for the light to change green, the car just died. All lights on my dash, etc. I put it in park, reset the key, everything was fine.
I drove it into the parking lot and did the self-check--all was well there. I let it sit for about 20 minutes while inside, then drove it about 5 miles home. No issues, plenty of power.
This morning, it was 8F when I left the house--car was very cold and after warming up no problems.
Any idea what might have caused this? I'm at 82k, I am about to change my plugs for the first time since owning it (bought it was 42k)--not sure if it was done before that.
Also, it's been so cold, maybe it was moisture? I have 3/4 tank of gasoline though.
Thanks for any ideas.
mine did that while driving the other day. No idea. I VAG'd it and had no codes, every
thing under the hood checked out okay. It was also cold when mine stopped.
My conclusion... it could have been: moisture, fuel pump, ignition, or something else electrical. It's been fine ever since but the car makes me nervous now. Anything could just be a guess.
Look at my posts on cold temp idle problems , try cleaning TB like Kris told me to.
I finally did it and car is doing much better .It has been -5 to 8+ around my area for past two days. I used about a 1/4 of a can of carb and choke cleaner from my garage cabinet , took the intake hose off at the TB end and sprayed cleaner in for about 15-20 seconds ,reattached hose and started car ,repeated 3 times and car now idles correctly and at higher rpms. Also add some fuel line drier as an extra measure in case its moisture in the fuel.
prestonian
Audi Original "S" Cars
10-03-2010 05:15 PM
bradstera2
12
02-19-2007 03:47 PM
EnzoA4
06-26-2003 04:49 AM
