Car wont warm up completely after new water pump, etc.
I replaced my water pump (fun) and after about 2 weeks, it will warm, but the coolant guages never read HOT and the heat is just warm.
This worked fine for about 2 weeks.
My only other deviation is that I also did just add a can of fuel injection cleaner a few days ago on a full tank of gas.
Could that be messing with something emissions-related that is causing it to stay cool?
Thanks in advance for any tips.
P.S., my 99 A4 1.8T Qtip is the biggest piece of crap known to man.
At 59K miles:
1) Rear wheel bearing
2) Dry rotted radiator hoses,
3) Broken dipstick
4) water pump failure
5) MAF sensor bad
6) Replaced timing belt.
Roughly $3G's worth of repairs on a $10K car with less than 60K on it. Woo hoo.
A Hyundai would hold up better.
My dealer really seems to like me, though.
(pardon the frustration)
At 59K miles:
3) Broken dipstick
5) MAF sensor bad
did you change the thermostat also??..put a new one in??...-->
I changed my waterpump/thermostat and fan switch all at once, makes great heat. Did you bleed the coolant system after you re-filled it???
Re: did you change the thermostat also??..put a new one in??...-->
I did not bleed it.
The how-to I was following did not suggest.
I do have a service manual, though. I will look that up.
Thx
Thx
Uh, I would not call your car crap based on what you list...
Age much more than mileage is the determining factor.
How did the dipstick break? I doubt it broke on it's own. Wheel bearings do fail, not remotely unheard of. When did the water pump let go? The MAF? also common. Do you have a K&N filter?
You paid 10k, or it's worth 10k?
Wtf
3) Broken dipstick
5) MAF sensor bad
How can that possibley add up to $3000
3) Broken dipstick
5) MAF sensor bad
