Combination Valve problem, Please Help!
Old May 25, 2002 | 11:11 AM
Vladimir's Avatar
Default Combination Valve problem, Please Help!
There is air gushing out of combination valve BASE, please see the pic. I shined the (yellow)light on the place where air comes out, on the more detailed pic. This valve is located on the engine head side towards firewall. There is a black plastic pipe and a small hose connected to the Combination Valve.
1)Is there a plug missing?
2)What is the reason the air is coming out of there? It becomes loud under load (moderate accelaration), well heard in 1st,2nd and 3rd gears. I idle, it is barely heard, but you could feel it with a finger.
3) Could something else be the cause ? (Secondary Air Injection solenoid[under the intake manifold])
PLEASE HELP,
Thank you Audi Techs and Friends,
<img src="http://pictureposter.audiworld.com/2734/dsc00083.jpg">&lt;br&gt;
<img src="http://pictureposter.audiworld.com/2734/dsc00085.jpg">
Vladimir
Old May 25, 2002 | 01:10 PM
Gjaime's Avatar
Default ok is it coming out of this picture?
<center><img src="http://pictureposter.audiworld.com/7171/usenow_copy.jpg"></center><p><img src="http://pictureposter.audiworld.com/7171/usenow1_copy.jpg">
This pic above? If you look under the valve, there are two bolts. That hold a gasket in place. It might be that one of the bolts came out. This happened to my 2000 a4 1.8TQ.
I had the same sound like you describe. Have someone rev the motor parked. And feel under the valve.
The fix was to put a bolt back in and hold the valve tight. Take a look and try to move the valve a little. Feel under there.
Or is it coming out of the last pic I circled?
I'll run out and take a look on my car.
jaime
Old May 25, 2002 | 07:32 PM
Vladimir's Avatar
Default Re: ok is it coming out of this picture?
It is coming out of the thing you circled with red.
Old May 25, 2002 | 08:06 PM
Gjaime's Avatar
Default I see in your picture. There is a slot? I put my finger on mine.
And felt no slot. I doubt it had some sort of plug, but you never know.
I'm looking in the bentley now. I take it you have a bentley too, since you know the name of the valve?
Just want to make sure again, so the air is coming just from the part I circled?
Did you check the two bolts were in the valve?
two bolts facing down. Really hard to see, but you can feel for them.
jaime
Old May 28, 2002 | 08:38 AM
Vladimir's Avatar
Default Thank you! I looked at it with a mirror..
found a hole, either punched through by some tech. loking for more work,.. or maybe it rusted through (really doubt it)..
Anyway, I put a Latvian penny, it fit just right, on epoxy there to plug it. Next day, checked everything is fine now!
Thank you!
a4_1.8t_01
Apr 20, 2021 11:23 AM
bigdawg56
Mar 23, 2017 01:33 PM
macleentrainor@yahoo
Dec 9, 2008 03:20 PM
FireBirdSC
Mar 23, 2006 12:11 PM
QuattroRocket
Sep 17, 2005 03:34 PM
