Cylinder 2 misfire problems
So My 1.8t that my wife drives started to idle really hard today and was throwing a blinking CEL. I tossed on the VAG and it was saying I had a cylinder 2 misfire. I instantly pulled the plugs to check them, swapped plugs, swapped coil packs to try to narrow them down. This didn' change anything. It is always throwing a cylinder 2 misfire. I then though it could be the fuel injectors (which it very well still could be). I pulled the fuel rail and the injectors and #2 definitely had some gunk on the end of it. I cleaned it up but put it back into the same spot because I jacked my shoulder and just wanted it to be back together at that point. Anyway, long story short it still is throwing a cylinder 2 misfire every time. Since this injector was gummed up is it probable that it is the injector that is causing the issues, or what else can I look for?
Thanks much in advanced.
Re: Cylinder 2 misfire problems
had the same problem. check the ICM.<ul><li><a href="https://forums.audiworld.com/a4/msgs/1594531.phtml">https://forums.audiworld.com/a4/msgs/1594531.phtml</a</li></ul>
yepodm
19
06-15-2020 03:15 PM
joec500
10
03-30-2006 07:15 PM
