HELP! How to remove Crazy Glue from Instrument Panel Lens!!
Well while I was installing gauge rings to my instrument cluster I managed to get two streaks of Crazy Glue on the exterior of the lens. I tried "goof off" and it had no effect. Can someone please tell me what to use to remove it?
THANKS!
THANKS!
I think you're pretty much screwed.
Anything you use to dissolve the crazy glue will likely haze the plastic. You'll then end up with a bigger mess on your hands...trying to polish the plastic again to make it semi-transparent again.
It will be time consuming but,
You can wet sand it off starting with 1000 to 1500 to 2000 and above grit paper. After you have sanded off the glue, use a medium grit polish and a finish polish just like a paint job. They even make plastic polish that will work even better. I hope this can help.
de natured alcohol
I put my rings on with super glue, I did the same thing, then I got some de natured alcohol and I cleaned it all off except one part, which I still I have to do.
My glue was dry about 2 weeks as well.
Hal_TT::CBP
10-21-2007 09:29 PM
mdwsta4â„¢uroslut
04-04-2003 05:12 PM
coocoomike
01-24-2003 03:25 PM
888
10-01-2001 08:13 AM
