Idle problems
Audiholic
Idle problems
Looking for suggestions. '96 AFC 2.8 with 106K miles. I'm having an idle problem. All appears normal at 750 - 800 RPM, then it suddenly falls off to 400 - 500 and recovers, or dies completely. Always restarts easily and runs well, but idle is unpredictable. No codes displayed in VAG COM
Audiholic
Re: Clean the idle control valve? Courtesy of Kris Hansen
Thanks for the reply. I had it out and all looks well. Ohms checked okay as well. I didn't pull the mounting flange for the valve. Any recommendation on cleaning the valve? What I could see of the plunger, it looked clean.
I'm not 12valve experienced. If the valve has been thoroughly cleaned and it still doesn't idle
properly, I'd surmise it was either a bad valve or perhaps you have a vacuum leak. Perhaps Kris or some other 12v owner will pop on with some advice. You can also post in the 12v forum ..<ul><li><a href="https://www.audiworld.com/forum/12v.html">https://www.audiworld.com/forum/12v.html</a</li></ul>
i got the same problem b4 .....
does ur engine go off while driving ? mine did .... i ttok back to sudi , then they told me it was ignition module disfunctions or something .... then $$$$ flied !!!!! damnit....
Audiholic
Re: I'm not 12valve experienced. If the valve has been thoroughly cleaned and it still doesn't idle
Found the tech site Kris has, and along with another input, all the guess work is gone. Will follow their suggestions and see what happens from there.
Re: No there is no idle control valve on the 1.8t. If you have an idle hunting problem it is more li
There "maybe" some confusion in terminology here, there is a Throttle Control Valve on the 1.8t which encompasses the Throttle Positioning Sensor.
Ultimately the throttle control valve on a 1.8t otherwise known as the throttle body is effectively an idle control valve among other things.
Kris Hansen
12-04-2001 07:15 AM
Bob Petruska
11-23-1998 04:41 PM
