need some input.
so here's the scenario, 2000 2.8 a4 quattro, 5 speed. car starts up well and idles fine. When the clutch is pressed down and you try to put the car in gear its like you shift off to lala land and have no idea what gear the car is in. a little while back i shifted from 1st to 2nd and after the shift the stick went back oddly far. Right now the car isnt engaging in any gears so its sitting. if anyone has any input it would be greatly appreciated!
im trying to figure out a game plan and my home shop is 2 hours away. Thanks,
Larry
Have you installed a 'short-shifter' in place of the factory shifter? If so, it is possible the linkage will need to be adjusted to allow the correct gear to be selected. There is also the possibility there is internal damage to one of the selector forks.
