Squeaky noise?
Old Nov 23, 2009 | 12:48 PM
Pete_A4's Avatar
Default Squeaky noise?
i got a 96 a4 2.8 AWD and i hear a constant squeaking noise coming from the back. I sprayed the upper control arms with lubricant and they stopped for a day then came back to squeaking? MY friend said it may be the upper control arm bushings? Anyone know how to fix and/or how much it would cost?
Thanks
Old Nov 24, 2009 | 05:51 AM
Bruch's Avatar
Default Check the springs
Thanks
When my rear springs broke, they rubbed on the shocks and squeaked. The bottom 2 inches of the coil broke and they didn't sit square in the perch anymore. After only 200,00 miles.....
Old Nov 24, 2009 | 06:39 AM
4corners's Avatar
Just went through this with our Avant. About $50 per side for the upper bushings and roughly 2 hrs per side for the r&r and pressing the old ones out and new ones back in.
Old Nov 24, 2009 | 12:42 PM
Pete@ECSTuning's Avatar
Audiworld Basic Sponsor
I beg to differ, my apologies. I did the job in 30 minutes on each side. The old bushings came right out and the new ones went in with a c-clamp fairly easy. This is def'n a DIY job. You need a 17mm for the wheels, and then a 17mm and 19mm (I believe) for the upper bushing. Then a c-clamp. Worked great for me!
And the bushings are only 18.95 a piece or 36.37 for OEM!
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
Old Nov 24, 2009 | 03:14 PM
Pete_A4's Avatar
def gunna have to give this one a try thanks alot guys
Old Nov 25, 2009 | 05:50 AM
Let us know how it turns out!
Old Nov 25, 2009 | 05:22 PM
MartinH's Avatar
I've done this replacement several times and tried the C clamp method with no success. The old bushes were in too tight. Ended up cutting them out and using a shop press to install the new ones. You need to make sure you don't press on the center of the bush as this will expand the rubber and hence the split metal housing and it won't press in to the arm. You need to use a sleeve that presses directly on the outer metal housing of the bush.
Old Nov 30, 2009 | 11:48 PM
TitusvilleAudi's Avatar
This is exactly what happened to mine!
I also have 201k miles on my baby..
Also, what kind of shocks and struts would you suggest as an upgrade if not willing to pay OEM prices?
Thanks!
S6Express
A6 (C7 Platform) Discussion
Jan 29, 2022 04:31 AM
Junius
Aug 11, 2016 06:48 AM
Minimarvel
Aug 4, 2016 04:37 AM
leftos
Audi A3 / S3 / RS 3 MKII
Oct 21, 2015 03:53 PM
changareth
Sep 25, 2015 11:27 AM
