Timing belt job suddenly needed at 126k
Old 01-08-2009, 04:37 PM
  #11
cparke's Avatar
Default Could the unplugged bank 1 cam adjuster have contributed to this problem?
Some idiot put a bank 2 cam adjuster into bank 1. Cam adjustment on bank 1 was therefore in the wrong direction (not good). Since I discovered this, I've been driving with bank 1's cam adjuster unplugged so that there is no cam adjustment (bank 2 is still plugged in).
Could this adjustment imbalance between bank 1 & bank 2 created an abnormal tension on the belt? Should I unplug both adjusters, or do I really have to change the bank 1 cam adjuster for the right part?
Old 01-08-2009, 05:07 PM
  #12
Tech Guru
4Driver4's Avatar
Nope. That idler is the weak point. It's just the way it is. :-(
Old 01-08-2009, 05:44 PM
  #13
MyDogDuster's Avatar
Default I had a TB break 1 mile from my mechanic a few years back...no fun.
<center><img src="http://pictureposter.audiworld.com/88353/p1070028.jpg"></center><p>Here what I was up to last night.
Old 01-08-2009, 06:22 PM
  #14
Member
77'911's Avatar
Default a response......
<center><img src="http://i42.tinypic.com/2mnogoz.jpg"></center><p>I'm sure the tech won't mind hearing some of your concerns. Its better then someone who beats the car up and abuses it.
Regards
Old 01-09-2009, 04:47 AM
  #15
Joey T
Guest
Posts: n/a
Default Tensioner arm.
The little lever that the tensioner pushes on. They get a notch on them after a while.
Old 01-09-2009, 07:05 AM
  #16
cparke's Avatar
Default Up to 30 bent valves doesn't sound exciting to me...
I never cease to be amazed at how someone can go through all the trouble to take the car apart to change the timing belt but doesn't get the right tools or doesn't change all the parts that run on it.
I've had a cylinder head rebuilt on another car from damage caused by a water pump failure, never want that to happen to me again!
Old 01-09-2009, 03:08 PM
  #17
Rack 'em Willie's Avatar
DO IT! I did the tbelt/waterpump 15k ago on my 2.8 and now the front main seal is leaking ahhh!
Gilbertorodz
10
05-25-2023 08:04 AM
galkokolaf
08-20-2010 01:43 AM
EEonA4
A4 (B7 Platform) Discussion
04-23-2009 04:16 PM
visintainer [vis]
17
07-25-2006 07:49 PM
BkLyNDuDe
08-16-2003 02:06 PM
Quick Reply: Timing belt job suddenly needed at 126k
