Vacuum hose
Old 07-07-2002, 04:42 PM
®ob's Avatar
Default Vacuum hose
Stumbled across this site. If you need to replace vacuum hose and are looking for colored hose...<ul><li><a href="http://www.hosetechniques.com/">http://www.hosetechniques.com/</a></li></ul>
Old 07-07-2002, 04:47 PM
bugbbq's Avatar
Default I've got hose....
in different area codes...
Old 07-07-2002, 05:00 PM
G0D
Elder Member
G0D's Avatar
Default hey rob...
would you happen to know the size of hoseses that I need for a boost guage? also what size t-fitting do i need? the t-fitting i got is 3/16 x 3/16 x 1/8 is that fine?
Old 07-07-2002, 05:09 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default I have to wonder about this stuff...
The previous owner of my S put the stock BPV's in place, and attached them with (what appears to be) blue silicone hose and nylon wire ties. The silicone hose appears to be very thin-walled, and I wonder if it will pinch under extreme vacuum? The nylon wire ties don't seem like a good idea either. Won't they become brittle with age?
In any event, I walked down to my local dealer Wednesday, and picked up some factory vacuum hose, and some Oetiker clamps to clean this up.
Old 07-07-2002, 05:33 PM
Senior Member
CharlieGSanD's Avatar
Default check this place out also.....
the site looks kinda shabby, but i have done buisnss with them numerous times &amp; they have always provided a great product with good customer support
they also have high quality silicone hoses.....<ul><li><a href="http://www.bakerprecision.com/">http://www.bakerprecision.com/</a</li></ul>
Old 07-07-2002, 05:40 PM
AudiWorld Expert
Digit@lex's Avatar
Default Hey Raj, got some pics of this Oetiker clamp?
Also, how much did the dealer charge for the vac lines? I'd like to replace a few of mine at 60k.
Old 07-07-2002, 06:06 PM
Member
Yippers®'s Avatar
Default Dunno about that OEM stuff and I'm not a fan of silicone either. IMO silicone is fine if the line is
routed very carefully and subjected to high heat but I think it kinks far too easily and certainly cuts too easily. I prefer good old vacuum hose to either silicone or OEM fabric covered hose. Plain vacuum hose is cheap and resists cutting and kinking closed. I don't like the OEM fabric because I think it can hide embrittled hose and it is expensive by comparison.
Old 07-07-2002, 06:53 PM
®ob's Avatar
Default Not off the top of my head. If in a bind just pick up on of those universal T fittings
They are plastic you can break away to get the right size.
Old 07-07-2002, 07:01 PM
James R.'s Avatar
In that case these guys are pretty good too, "http://www.roadraceengineering.com/"
Old 07-07-2002, 07:02 PM
James R.'s Avatar
Way expensive and goes brittle 10 mins after you put it on :-(
Quick Reply: Vacuum hose
