Blinking Engine Light
Tip #3: Post full vag-com error codes (with description, not just numbers)
Tip #4: Don't drive the car when it's obvious that something is majorly wrong.
Tip #5: Don't drive the car with a blinking CEL.
The symptoms that you've described sound like a textbook case of a failed coilpack (shaking, hesitation, red cat, smell, etc).
<a href="https://forums.audiworld.com/a4gen2/msgs/1003672.phtml">Coilpack replacement DIY</a>
Your codes:
P0102: MAF may need replacement
P0444: not sure
P0302: Misfire detected on cylinder 2.
Replace the coilpack on cylinder 2. You should've done that in the first place.
Or and did I mention that you shouldn't drive the car witha blinking CEL?
Vag-com is a software programs that allows you do read all the fault codes and do other things.
www.ross-tech.com
I assumed that you were using a vag-com.
It gives a more detailed description such as:
P0302 - Cylinder 2 Misfire Detected
* "If the part you replaced doesn't fix the problem, you now have a spare."
Yes, those symptoms seemed to scream out "coilpack." Replacing the cat seems a bit like another quote, said by my high school history teacher:
"Get the axe, there's a fly on baby's head!"
