HELP!!! I can't get the hubcentric rings off my car!! What do I do??
So I was trying to take my 18 Inch Flik Arctics off my car, so I could put my stock 16's back on for a bit, and my right left hubcentric ring wont come off the car! I tried everything, I just can't seem to get it off. Guys give me some suggestions, without sawing it off! What could I take to it to get it off? I know its a tight fit, and I have a feeling, thats probably what it is...?? Give me a hand guys, I know some of you are miracle workers concerning this kind of stuff.
Jonathan
Jonathan
Get a large heavy duty screwdriver (3/4"wide tip, 15" long) and a 3# hand sludge hammer...
or just a large 16oz hammer & locate the spacer/hub seam, place screwdriver tip @ that seam and give it a few firm taps...
That should free it up...
If not, spray some liquid wrench into the seam and let it penetrate (Careful not to spray brake calipers)...Repeat above.
liquid wrench, WD40,and a pr of slip joint pliers or even..
a pipe wrench to twist it off. Be carefull not to chew it up. I now carry a thin broad bladed srewdriver in case I get a flat and I'm on the road trying to change the wheel.I try to wedge it behind the ring and pry it off.
Hugh
Hugh
WD40 and a very thin broad flat-head screwdriver is all you need.
Spray some WD40 around the edges and use the screw driver gently around the ring to slowly pry it off. the key word is gentle.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
carl viking
36
04-27-2020 01:17 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
