OK electronic folks...
I know this has come up before, but searching didn't give any solutions... Yesterday I installed my XM Commander, wired to my radio via the Blitzsafe AUX adapter that I had previously been using for my iPod alone. I put RCA Y-connectors on the blitzsafe, and connected both my iPod and the XM Commander unit. All said and done, the iPod works normally as it has in the past, and the XM Commander works well except for bad distortions in songs with a lot of bass. I've read something about people having this exact same problem, but what's the solution? Should I modify the Blitzsafe adapter? Thanks
ALSO... for those with XM Commander...
How are your units connected? Do you have iPods? Use Blitzsafe? Which Blitzsafe? I wouldn't mind using the FM Modulator, but the supplied connector is for the motorola antenna jack, which our cars don't use. possible solution to this problem for those who have tried it? thanks
forgot to mention... i turned the output all the way down
on the xm commander and there's basically no change... oddly, i don't think that did anything. other ideas?
are you trying to run both at once?
perhaps you could try to power one at a time.. or create a switch to go back and forth between inputs. i'm sure someone will chime in. sorry i cannot be more help.
Ray_QT
Q5/SQ5 MKI (8R) Discussion
21
10-02-2015 01:50 AM
vansoffyomama
09-28-2015 04:38 PM
Audi Other S6 2002 FS
dorschman
09-17-2015 03:24 PM
