P0322 code and still running
Old May 25, 2009 | 05:51 AM
Athos76's Avatar
Default P0322 code and still running
My CEL popped this morning and I didn't have a vag-com, but I stopped at Autozone to scan. P0322 popped and I brought it to my hangar to check it out. Well, upon further inspection, my engine speed sensor isnt there. How can the car still run? I've looked for loose wiring and everything. I noticed the missing plug the other night while doing a tire rotation, but didn't think it was the sensor, I thought it was the port to find TDC...
Any suggestions? Besides replacing the sensor...
where does it connect?
2004 A4 Quattro 1.8t stock...
Old May 25, 2009 | 06:18 AM
Athos76's Avatar
ignore parts of the last post.
-I do have the p0322 code.
-I do have the Engine Speed sensor where it should be...
What I don't know...
There is a similar size and shaped port (as in the Engine speed sensor), but it is located on the transmission below and behind the oil filter. I can see a gear in it and there is currently nothing there....
What could it be?
Old Sep 25, 2024 | 04:36 PM
AMarenco's Avatar
Default Solution
Hey, having the same issue on my Audi a4, did you find a solution?
Old Sep 27, 2024 | 10:59 AM
Cybersombosis's Avatar
What appears to be the issue? The crank position sensor is located behind the oil filter and has a grey connector on the firewall. It’s part of the engine, not the transmission. There is also a hole in the transmission but nothing should be in that hole.
saranaz
Nov 8, 2010 12:58 AM
agrandy
Jun 9, 2008 05:26 AM
Small Town Terrorist
Audi Original "S" Cars
Dec 22, 2006 02:07 PM
