timing belt snaped
timing belt snaped
i had the timing belt snap on me while i was driving and so when i got it back to the house i was going to put a belt on it to see if i had anything messed up inside the motor.I lined up the timing mark up on the cam shaft sprocket with the mark on the valve cover and then i lined up the mark on the crank shaft pulley with the mark on the timing belt cover and proceeded to put a belt on and cranked it by hand a few times before trying to start it. it turned easy and didn't hear any metal hitting or ticking or any sound out of the ordinary. so i tried to start it and i got nothing. Everything is turning with no bad sounds.i checked the plugs and i am getting spark , they kinda smelled like fuel. i tried spraying starting fluid in it and still got nothing. Next i ran a compression test on it and the needle didn't move at all on all 4 cylinders. That makes me think thats its still out of time but with both marks lined up and cylinder number one at it is highest point i cant figure out how it could be outta time. Any suggestions on what i should do or what i should check would be great
so should i see if i can get a whole new head, the motor has over 200k on it , is it even work fixing or should i just get a new motor and then my other option is to just sell the car as is and see what i can get out of it
