Vagcom errors
Vagcom errors
Hello experts,
Newbie here looking to see if i can save some money and take on the work myself. However, I don't know what to change/check to see what is needed. Some guidance, drawing, instructions would really help me here as I am a visual learner. See below for a vagcom reading on an audi 2005 A4 B6 1.8T ( 250,000 km). The only error i see on my cluster is the symbol for ESP.
I cleared all codes multiple times but they come back.
Also, the passenger side door panel light ( and back door panel light come on intermittently). Equally. when I open the passenger side back door and put my little one in the car seat(as the door is open) the system/alarm activates and the back interior light does not turn on even when the back door is open.
VAG-COM Version: Release 311.2-N Chassis Type: 8E - Audi A4 B6 Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76 Address 01 ------------------------------------------------------- Controller: 8E0 909 518 BC Component: 1.8L R4/5VT G 0040 Coding: 0016711 Shop #: WSC 93246
2 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded - Intermittent 17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
P1290 - 002 - Lower Limit Exceeded - Intermittent Readiness: 0000 0000
Address 03 ------------------------------------------------------- Controller: 8E0 614 517 A Component: ABS/ESP allrad 4529 Coding: 04275 Shop #: WSC 06435
1 Fault Found:
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
Address 08 ------------------------------------------------------- Controller: 8E0 820 043 AD Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 06335 No fault code found.
Address 09 ------------------------------------------------------- Controller: 8E0 907 279 F Component: int. Lastmodul KAN 0517 Coding: 01014 Shop #: WSC 00000 No fault code found. Skipping Address 15-Airbags
Address 16 ------------------------------------------------------- Controller: 8E0 953 549 N Component: Lenksᵬenmodul 0611 Coding: 01041 Shop #: WSC 06335 No fault code found.
Address 17 ------------------------------------------------------- Controller: 8E0 920 900 N Component: KOMBI+WEGFAHRS. RB4 D42 Coding: 01301 Shop #: WSC 93246 WAULC68E05A118409 AUZ6Z0D0319549 No fault code found.
Address 46 ------------------------------------------------------- Controller: 8E0 959 433 BB Component: KomfortgerᴠT7B 1612 Coding: 11848 Shop #: WSC 06335
5 Faults Found: 01371 - Alarm triggered by Door Contact Switch:
Driver's Side 35-00 - -
01574 - Alarm triggered by Door Contact Switch: Right Rear 35-00 - -
01573 - Alarm triggered by Door Contact Switch: Left Rear 35-00 - -
01560 - Passenger Door 59-00 - Can't Unlock
01562 - Right Rear Door 59-10 - Can't Unlock - Intermittent Address 55 ------------------------------------------------------- Controller: 4Z7 907 357 Component: dynamische LWR D09 Coding:
00060 Shop #: WSC 06335 No fault code found. Address 56 ------------------------------------------------------- Controller: 8E0 035 195 G Component: symphony II PM6 0410 Coding: 01201 Shop #: WSC 00003
1 Fault Found: 00858 - Connection: Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit End -------------------------------------------------------
Thanks...
2 Faults Found:
1 Fault Found:
Thanks...
Is there a problem you are highly focused on or are these just random things to worry about?
It looks like there are a couple faults that need to be addressed. You need to record the scan log BEFORE you erase everything when attempting to clear DTCs. You need to begin by reviewing the date on which the error was recorded. You can't get too tense about things that occurred 3 yrs ago and haven't shown up since.
I am concerned with all these issues to be honest but because the ESP light is on my cluster I am most concerned with this. I read that the brake light sensor may need to be changed but not sure how to confirm this.
As for the dates, even when i clear these errors the same ones keep coming back (have recorded the log before erasing and then comparing this to a new run 3 days later).
Also the radio reception is bad and the panel lights and locking of the doors is inconvenient especially when I need this working most.
Thanks again.
EricVonHa
02-02-2012 06:41 PM
A6w2.7T
04-20-2006 10:44 AM
