A4 2009 Eating engine oil
Other then taking it to a dealer or another shop you are experiencing the piston/rings problem. First have the PCV system checked to make sure there isn't a problem there. You could go through the oil consumption test but my bet is you are way past this and will most likely need the piston change to fix the problem. Good luck
