Bulb / Led Tail lights question.
Hi there!
I had oem bulb tail lights and i repleaced them with led ones. The thing is when i click the turn signal or push the break, only the outer light is lighting "brighter" and the inner one ( light on the trunk ) stays same like in the parking.
Do you think i can change that so i can have them both (inner and outer) lights up brighter ( Like in 2010+ a4 oem led) ?
If yes, only coding is needed or do i need to do the wiring / or something else?
Thanks for the reply.
See if this helps answer your questions. http://www.audienthusiasts.com
Hi there!
DavidB8 from audienthusiasts.com is the only person I know that can help you. He's always swamped with emails and PMs from AZ. Don't forget it's the Holidays too. He could be on vacation.
To make sure I'm getting this right. Only your outer lights are turning on when you turn on the directional or brake?
Thx for the reply ill try to contact him.
sundaekim
Q5/SQ5 MKI (8R) Discussion
11
05-29-2016 05:29 PM
grifter1818
A4 (B8 Platform) Discussion
02-29-2012 08:59 PM
SpeedyDTP247 CQ+UrS4
9
12-22-2007 10:37 AM
craigd0013
02-17-2004 08:14 AM
