Coding for turning on Audi Active Lane Assist (all cars with pre sense)
#751
Just a frustrating comment to share... You can have a vehicle with Pre-Sense that this will not work for. If you're using ODBeleven and the A5 module isn't showing, it won't work for you.
Source: Have a 2018 Q5, with pre-sense, that does not have the same camera as you guys have mentioned before.
#752
Someone said that turning traction control to sport will turn it off. Since most of us are not racing around city streets, should be a good work around. Someone on here is trying to, but it appears there is some steering wheel angle recalibration/reset that nobody knows how to do after you get the new steering color with correct stalk.
#753
My experience is that putting into "Sport" or turning it off does disable lane assist.
#754
Putting the car in Dynamic mode doesn't put traction control in "Sport". You do that by hitting the traction control button on the console, and you'll see a message on the dash. Holding the traction control button for several seconds turns it off entirely.
Thank you for clearing that up!
#755
To quickly (and briefly, hopefully) deactivate ALA (after coding it on with OBDeleven) you need to turn off Electronic Stabilization Control (ESC). The ESC deactivation switch is located on the center stack - see page 141 of the online owner's manual.
Be aware that if you deactivate ESC you will lose stabilization control, traction control and your pre sense systems. As well the operation of other integrated systems are impacted. Be sure to review the ESC section of your owner's manual before arbitrarily turning off ESC.
Turn off ESC at your own risk!
#756
Thanks for the clarification rbreeze. Turning off ESC is probably something I’m not interested in doing, looks like I’ll drive around with ALA on for a while and decide whether to keep it on or off.
#759
I just purchased ODBEleven and installed it on a cheap Android phone I bought just for this purpose. I was fully prepared to do the coding in this thread to enable this feature, but It's showing that Active Lane Assist has been added as an app. If I use the pre-installed app, is there any other coding needed?
