Engine Code Difference - CYMC vs DBPA
My current vehicle MY06 Audi A6 3.2 FSI Quattro with around 83,000 miles, engines still runs fine but I have also stuck to premium fuel if that helps.
I wonder if Audi has thought of a way to service the dirty valves from carbon - probably not...
www.youtube.com/watch?v=dDQ006hVAVA
edit - I get your point now; you want an MPI engine so you don't have to deal with the carbon issue of the early FSI engines. Are others with Gen3 evo engines having carbon issues? I've got 222k miles on my Gen2 engine and though I've done a rudimentary cleaning two times along the way, there was never any carbon build up of significance and the cleaning made 0 impact on engine operation. Others have had significant carbon such that idling was rough among other issues.
You are absolutely correct, I am looking for the most reliable car possible. My current Audi is V6 so may be less prone to carbon build up, I have no idea. However, now that we are aware of the issue I would like to chose the best car/engine possible. That's why I am trying to find one with MPI but I suspect it will be difficult (especially as I have a long wish list concerning the options and extras).
11.7:1 by reducing the volume of the compression
chamber.
> Modified squish zones in the combustion chamber.
> Lowering of combustion chamber ceiling by 9 mm.
> Modified piston shape.
> The intake ports have been redesigned, that is, made
straighter, to optimize charging motion.
>The positions of the spark plug and high-pressure inject-
tor as well as the shape of the piston have been adapted
to the new combustion chamber design.
> Valve guide housings, modified for better heat dissipation.
>Double-lip exhaust valve stem seals.
https://static.nhtsa.gov/odi/tsbs/20...05867-2280.pdf
