Tire rotation uh oh.
#21
Thanks for sharing. But yeah, that confirms the type of rotation pattern I was suggesting for AWD(just so happened I used NJ on/off ramps as a reason). Also 5k seems a bit quick but I guess it really depends on how you drive. I generally do 10k but have done it around 7 if I saw quicker wear on one side.
#26
Don't overthink it.
Buy a $5 tire depth gauge and measure twice a year. Like many of you I take my wheels off automatically every 6 months when swapping winters to summers and vice versa, so that's when I do it.
Rotate based on measured wear, with an awareness of your tires' symmetry, directionality, or lack thereof. Typically you will notice that on most cars the front left exhibits slightly more wear than the other 3 tires, and the rear right exhibits the least, so that is where the advantage of rotating the front left tire to the rear right axle comes in if your tread direction/symmetry allows for it. This wear pattern is because of how the car loads when taking exits/offramps/etc -- we take more right turns/curves than lefts. However on cars with quattro the wear is usually astoundingly even and it matters a lot less than it does on a Honda.
#27
Don't overthink it.
Our Honda's on the other hand have always eaten front tires. I'd guess that the fronts see twice as much wear as the rears, even on an AWD vehicle.
#28
I'm at 26k on my A4 and have never had the tires rotated and the remaining tread is almost identical front to rear. I do have about .5mm more wear on both right tires than the left. The Pirelli P7s that are on the car don't appear to be directional, so I guess that I should get them rotated as per the pamphlet rather than the owner's manual to try and balance them out a bit.
Absolutely on the Hondas, though. They are notorious for understeer and will burn through fronts due to plowing, being front heavy, having part time AWD systems, and lacking any BBTV or clever techniques to steady the chassis.
xradman
01-02-2012 03:55 PM
JMS-Four
Pacific Northwest Discussion
11
01-29-2007 12:55 PM
