Audi A6 C7 FL Traffic Sign Recognition retrofit guide
Old 02-19-2021, 09:10 AM
  #31
Irmantas Paura's Avatar
Hello. Yes, I have sara3. I can get sara6 with codes 4G0907637B or L. Which is more suitable? Thank you
Old 07-15-2021, 04:01 PM
  #32
MrGimper's Avatar
Originally Posted by Rizzio
MrGimper : whats your location? Us? Eu? If in the us, after what i have figured out, the street sign recognition wont work, and the country your in have to be suported
Some newer audi cars have recognition for mph signs
Apologies, I know it’s been some time. I’m in the UK. Do I just need some software tweaks as I have lane assist, adaptive cruise control etc.
Old 02-19-2022, 11:03 AM
  #33
aldinsusa's Avatar
The suffix F for the camera and H for the imageproc is for the facelift.
You might want to update the software bit of the camera to B or E. You need the VCP for that process.
is the lane assist working?
Rizzio can you help, I have Audi A6 2012y with acc and break guard installed. My acc camera isnt working and need to be replaced and calibrated. My car is Audi A6 C7 2012y oem part number of my camera is 4H0907217A, my friend offered to send me camera 4H0907217F. I know the second is for the face lift A6 C7 2015y and A8. Do you know if it can work on my car with some coding or software update and how to do it?
Old 02-19-2022, 11:06 AM
  #34
aldinsusa's Avatar
I made mistake, my oem number of camera 4G0907217A
Old 02-25-2022, 06:19 AM
  #35
spenchev11's Avatar
Rizzio,was your country supported for TSR ? I am from Bulgaria and it was omitted for the c7/c7.5 6/7 cars.I have an S7 facelift bought fromGermany with the system factory installed and activated.TSR works OK in western europe,however it says “outside operational area” in my country.I managed to activate by altering the last bit inbyre 24 in the 5F module,which i believe concerns predicitve route data.By unticking it the system works,reads the signa,however sporadically a “speed limit display - currently restricted” appears on the display,but the system keeps on working - showing only the signs read from the camera,although the adaptation is set to fusion.I have separate speed limit shown on the MMI.I saw a couple of videos on youtube originating from Slovenia and Romania/countriea not originally supported for TSR,and the system works without the fault appearing.Those users offer coding services,however that cant be done remotely.Do you guys have any ideas on what further coding can i implement to get rid of the error on the MFD ? I tried playing with coding on the camera and image processor- turning off predictive routing,setting the mmi to no navigation,fusion adaptations.All that to no effect.Also i have updated the software through VCP,and ran the script for activation - although i have it active.
Thanks in advance.
Old 10-21-2022, 09:54 AM
  #36
OriginUnknown's Avatar
hello. im quite a newbie here, same as with vcds but ill try doing this upgrade to my A6. can someone please tell me if i need to do anything else, or just vcds coding ? thanx in advance.
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 28 3B 42 44 46 52 53 55
5F 62 6C 6D 72 85 8B 8E 8F 90 AC
VIN: WAUZZZ4G6HN091294 Mileage: 126598km-78664miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-DDDA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 HA HW: 04L 907 309 AA
Component: R4 2.0l TDI H20 3830
Revision: 8DH20---
Coding: 12254012246401080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021HA 004003
ROD: EV_ECM20TDI01104L906021HA_004.rod
VCID: 6BD572AB8285F9175C-803E
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G1 927 153 B HW: 0CJ 927 156
Component: 0CK 20TDI RdW H03 0004
Revision: --H03--- Serial number: 0000001490
Coding: 100001
ASAM Dataset: EV_TCMDL382021 002024
ROD: EV_TCMDL382021_AU57.rod
VCID: 295948A348F92B07EE-807C
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071170009000777
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Revision: -------- Serial number: --------------
Coding: 06A29E49604579929B00
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 4189F003D089C347D6-8014
3 Faults Found:
161024 - Tire Pressure Warning
C102D 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
161280 - Tire Pressure Warning
C102D 00 [032] - -
161536 - Tire Pressure Warning
C102D 00 [032] - -
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
Component: BCM2 2.0 H61 0825
Revision: 00002001
Coding: 01A9700E000000000000
VCID: 7CF741F7FFEB6EAFC5-8028
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0113
Serial number: 13011700040838
Coding: 34020978250000
ASAM Dataset: EV_AirCondiComfoUDS 003008
ROD: EV_AirCondiComfoUDS_003.rod
VCID: 63C51A8B6A55B157E4-8036
1 Fault Found:
0404 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 5
Reset counter: 241
Mileage: 126306 km
Date: 2022.09.20
Time: 18:44:11
Voltage terminal 30: 13.25 V
Outside air temperature: 16.5 °C
Engine speed: 1375 /min
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 15020001 Serial number: 00001566707102
Coding: 0105001440349FE2C101408320001800CF9CC7082E08020100 000894E10114020040003C030000
VCID: 74E769D7D7BB26EF8D-8020
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 161118 H38 0080
Serial number: 161206190445
Coding: 0045F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 20091861X81A955547A0
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 19 01 2017 00000646
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 9D588A8800PAG0MUFU03
1 Fault Found:
03608 - Humidity Sensor in Fresh Air Intake Duct
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 5
Reset counter: 241
Mileage: 126306 km
Time Indication: 0
Date: 2022.09.20
Time: 18:44:16
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 B HW: 4G0 907 561
Component: ACC3 H21 0055
Serial number: 00000000000000
Coding: 7C04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
ROD: EV_AdaptCruisContrAU57X_002.rod
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0092
Revision: -------- Serial number: 003P100CF85Q
Coding: 30333130313630323531554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 3B7582EBB265A9978C-806E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40574D7QA6GVW
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB40574D7QA99RP
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB400S599TUM8LL
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB400K57E44LA9+
Crash sensor for front airbag: driver side:
Serial number: 3554VRB400S59714K901
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB400U59714FOU1
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H05 0005
Revision: -------- Serial number: 90372QAD000BJ
Coding: 00003D
VCID: 377D9EDB864D8DF768-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0010
Serial number: 26 11 2016 C0050217
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 935 A HW: 4G8 920 935 A
Component: TDieRdwAcc H15 0225
Revision: 15001308 Serial number: 658100117592034
Coding: 138F15000F410008000000
Shop #: WSC 62875 003 104857
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K_AU57.rod
VCID: 306FA5C76B235ACF29-8064
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002495182
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 002000
ROD: EV_GatewPkoUDS_002_AU57.rod
VCID: 3D718CF3AC71A7A7B2-8068
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Component: J367-BDMHella H10 9070
Serial number: 4706162504
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 16111600000000000145
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04018264747464545425363E00
VCID: 67DD0E9B966DDD7738-8032
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0113
Serial number: 20011700041140
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
ROD: EV_ClimaContrUnitRearUDS_003.rod
1 Fault Found:
0068 - Position Sensor in Rear Left Upper Body Vent
B10E5 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 216
Mileage: 123031 km
Date: 2022.08.13
Time: 11:01:45
Voltage terminal 30: 13.42 V
Terminal 15 status: Terminal 15 on
Supply voltage for external components: 5.00 V
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA820CWXXS
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 366393DF894774FF73-8062
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0511
Coding: 011F17015C00628002080003
VCID: 4581E413CCA1EF67EA-8010
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H56 0202
Revision: 00000002 Serial number: 0000163482
Coding: 101000010001
Shop #: WSC 62875 003 1048576
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A7B87EFBD5F909F97-806E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0429311152
Coding: 0100063820B93080C32009840C010F47000000000000000000 0000000000
Subsystem 1 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00027814423
Coding: 010000
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0511
Coding: 011F17015E00628002080002
VCID: 4683E31FF1A7E47FE3-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
Component: EPB-4 H01 0018
Revision: -------- Serial number: 00000002079692
ASAM Dataset: EV_ParkiBrake 001033
ROD: EV_ParkiBrake_VW51.rod
VCID: 326BAFCF652F68DF5F-8066
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 04FA02102A630200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
VCID: 3467A9D79F3B66EF4D-8060
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 4G1 035 044 G HW: 4G1 035 044 D
Component: MU-H-LN-EU 053 0910
Serial number: A734A0H7541206
Coding: 017502010000000013110002000A00332F0006E5F1700100DF
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
VCID: 23455A8B2AD5F157A4-8076
Data medium:
Subsystem 1 - Part No SW: V03 959 801 FC HW: -----------
Component: ECE 2017 --- 0157
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY806Z3U
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349QAG0004H
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1015
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0511
Coding: 010F15004000628002080002
VCID: 4999E823E0B90B070E-801C
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 0275000102002003000040
ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
VCID: 78FF5DE7C3D3428FA1-802C
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0152
Revision: 14005001 Serial number: 009700632
Coding: 093205C010
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0511
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H28 0081
Revision: -------- Serial number: 262130025421000
Coding: 6A040000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C57B1B7470B3E2F15-8078
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 B HW: 4G0 907 541
Coding: 7C04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 275D4E9B5EED1D77F8-8072
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H34 0090
Serial number: 005002452312167
Coding: 0480A8181111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H16 0080
Coding: 00660600031F0376000308014248D2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3169A0C3602953C726-8064
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Address AC: Reductant Control (J880) Labels: 4G0-907-355.clb
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 163471202
ASAM Dataset: EV_RDCMA00100 008040
ROD: EV_RDCMA00100_008.rod
VCID: 2F6DA6BB761D453730-807A
Mrclopec
Q5/SQ5 MKI (8R) Discussion
24
02-17-2021 11:04 PM
andru1313
VAG-COM Discussion
11-27-2017 05:23 PM
Mrclopec
VAG-COM Discussion
05-27-2015 04:10 PM
danikas
VAG-COM Discussion
11-02-2014 01:43 PM
danikas
A4 allroad (B8 Platform) Discussion
10-01-2014 05:48 AM
Quick Reply: Audi A6 C7 FL Traffic Sign Recognition retrofit guide
