Feasible to swap in OEM sport suspension?
#11
Why not buy a set of Eibach or H&R sport springs for a couple hundred $$, have an install done with an alignment for another couple hundred $$ and you're done in one day. It'll lower the stance about 3/4-1" for a great look and tighten the ride only a bit. NO need for rim or tire changes. I did this to 2 of my S4's over the years without ANY ill effects. Do it all for<$500. Find a decent indie German car mechanic and that's all you need. Check it.
Add that I had coilovers installed on another S4 and it was the WORST decision I ever made, both in cost and in final results.
FWIW.
FWIW.
#14
Curious why wheel size enters into this mix if it's oe unless the diameter is not consistent with the model. Sticker on the door pillar will tell the tale. Point being whether it's 19 or 20, diameters should be the same thereby not affecting electronics/speedometer and easy to calculate-if needing to do so. Another point is rim size should not play into the suspension choice either unless the stiffness of a sport suspension dictates a less aggressive aspect ratio. Adding to this is the road quality where you live, geographic area of the US...northeast US being sucky.
#16
Maybe a bit OT but several here have 'VCDS' in their sig. Can you expand on this meaning please.
#17
The condition of roads in the northeast is not conductive to the sports suspension. I had two great A4s with sports/summer tires and am on my second A6 with standard suspension and 18" wheels. I change to Michelin X-Ice winter tires because wheel/tire sets are too heavy for an old man. I have had sports A6 loaners and many rides in an associate's A6 sports. It handles sharp but is harsh. If the roads were decent the ride would be fine. Real winter tires are fantastic. Stay with the wife you have not the one you want.
akaplan12
A4 (B9 Platform) Discussion
11
03-10-2019 06:04 PM
daboyzz
10
01-31-2007 07:08 PM
Black Sunshine
06-24-2003 10:00 AM
