Turbo aficionados please tell me about this Audi A6 2L T engine
#11
The only other thing I can think of is;
1. Possibly aged coil packs. The housings can deteriorate and moisture can get in resulting in misfires?
2. Dirty mass air flow sensor ( MAF) ?
3. Dirty oxygen sensor?
#12
Re-read your original post as I didn't notice the misfiring statement. That is most definitely unusual. Do any idiot lights come up? Sounds like maybe the pump has such a high electrical draw that the alt can't cope with everything?
The only other thing I can think of is carbon build-up around the intake valves - but that normally occurs close to 60-70K miles and you'd notice it across the entire powerband, not just cold idle...
#13
Is that guy near the air filter box? Can someone point me to it?
Could be the coil packs. Changing the plugs did nothing.
Thanks
#14
Regarding the coil packs, I would simply inspect them for cracks.
#15
Thanks Farher, I found it, took it out (from the filter box) and cleaned with MAF cleaner. Letting it dry now before I start it up....
I had taken the coil packs out when I changed the plugs and had not noticed anything weird other than old baked dielectric grease around the outside.
Will report back soon if MAF cleaning took care of things on a cold start.
#16
Well I'll be!
I noticed a much smoother engine on the first cold start after cleaning the MAF! It was not perfect, but that seems to have improved the smoothness (less sudden/ acute engine vibrations) quite a bit.
Will see if it stays this way...
peter1045
10-05-2017 03:32 AM
Skyler@Achtuning.com
13
10-27-2006 08:40 AM
