Help with some codes
Old 02-01-2012, 05:14 PM
jseklund's Avatar
Default Help with some codes
Ok, so I'm really beginning to hate my mom's 01 2.7T A6. This thing always has issues, which I get to fix.
At any rate, she called me today because she had an oil light come on. I'm not sure which light - if it could be low oil, oil sensor, or oil pressure, and the light is gone - so I scanned with vag-com.
No codes related to the oil pressure were in the VCDS, which I am not sure they would be anyway.
There were, however, 5 codes:
17862 - EGT Sensor short to ground.
17866 - EGT Sensor short to ground.
16486 - MAF signal low
16684 - Random Misfire
16690 - Misfire Cylinder 6
I had to replace the EGT sensors on this car about 2 years ago (approx. 40,000 miles or so). I hope they haven't gone bad again.
This is the same car that I had to replace a head on, and it has had a rough idle ever since. When I first replaced the head, the rough idle was constant on cylinder 4. I ran it with the vag connected and didn't see any misfires on the counter tonight but it still idles like hell.
I cleared the codes....but I'm wondering if the MAF would cause the EGT codes?
I'm looking for opinions on what could cause this and how to troubleshoot these items...thanks...
Old 02-03-2012, 03:23 PM
jseklund's Avatar
Just a bump in case anyone has any thoughts and might of missed it. I'll let it die after this if there are no ideas...
Old 02-03-2012, 03:45 PM
rohit13's Avatar
you should cross post this at audizine so you get the multiple views.
the s4 people and a6 can probably help you out.
Old 02-03-2012, 04:37 PM
jseklund's Avatar
Great thanks!
mikemillion2000
01-15-2017 10:03 PM
ay6
09-11-2015 03:47 PM
bradpederson85
04-05-2010 09:40 AM
slow_N_lowe
01-21-2009 07:07 PM
lemieux@curbside
13
12-31-2005 04:33 AM
Quick Reply: Help with some codes
