How hard to replace complete tie-rod assembly ?
My inners are totally shot and I'll be replacing the outer too, so I guess i'll be enjoying much much tighter and precise steering soon!
Anything I should know? Tips, tricks, potential problems? I found the pipe-wrench method while STFA, seems easy enough. I guess it's also easy to avoid an alignment if I remove the complete assembly and make sure the new one is exactly the same lenght before assembling on the car right?
Thanks!
G
Thanks!
G
Um, no. You need to have the car aligned when you are done.
The hardest part of the job is getting the rack boot off and on and getting the clamp crimped down again. A new clamp from the dealer helps, as does a long nosed pair of needle nose pliers.
I like to replace the boot at the same time.
Don't know of the "pipe wrench method" to which you refer, but clearance will not allow a...
conventional radial handled pipe wrench access to the ball socket on the end of the rack. I have and successfully used a chain type pipe wrench which accepts a ½" sq drive extension axially, parallel with and immediately adjacent to the pipe. That inner ball socket is very tight on the rack end, requiring a breaker bar.
I needed to do this just to free up the outer ends for toe alignment purposes. So lube the threads on the outer TREs for easy toe alignment.
not that tough
but the inner boot clamp is a PITA.
If you don't have the remote clamp tool and go with a traditional screw clamp its worlds easier with a 1/4 inch air ratchet.
I took the cover off of the tie rod area, set the clamp on there and was able to get a 1/4" air ratchet in to tighten it down.
I would have gone nuts trying to do it by hand.
If I remember correctly for how long the inner looks its actually very short and you can get it off/on very easily. The boot is the hard part.
greenaudiurs4
09-20-2010 07:18 AM
pmark837
06-30-2005 11:07 PM
lemieux@curbside
08-22-2004 06:37 PM
RussB
07-21-2003 08:13 PM
