Replacing door lock latch mechanism
Hello.
I am in the process of ordering a new door lock latch mechanism for my A6, since the passenger front door someetimes mailfunction when opening it with the remote, and also the microswitch that detects if door is open or not is not working anymore.
What is the easiest way of replacing it ? Do I have to remove the window frame ? How is it attached to the door / lock ?
Thanks for all answers.
Vegard
Vegard
Hello.
Thanks for the reply and advice.
I have been doing the search as you described, but I can only find explanations for the DRIVERS side, not the passenger side. To me it looks like the drivers side is much more complicated to remove than the passenger side, due to the presence of the lock cylinder, but I could be wrong.
Thats why I asked for help here.
use the drivers side guide , its the same .. the door lock cylinder is a very minor step you will be able to skip.
but since you will have the window regulator out would be a great time to upgrade to the pink slider clips since you are 99% of the way there.
Thanks for the advice.
I have already replaced the sliders, didnt get the upgraded once, tho, since I already had some donor sliders from another car. But will look into getting a new pair just in case.
I've done DS on my car & now awaiting PS to replace it. I've had intermitant problem where latch won't release from inside or outside handles. Not good, can't open the door. Finally lucked out & got door open after manny tries. It appears the the latch hook, that pivots when it engages the jab bar, gets worn by contact with the microswitch button. When handle pulled, friction from the microswitch button doesn't let the latch pivot, & door doesn't unlatch. The button wore a groove into the rubber coating of the latch hook & gets hung up there.
Nope. Must pull the door panel to get access to the lock mechanism.
its a part used in an application it was not designed for , and also these crs are lasting a long time so unusual parts are starting to wear out ...
the microswitch is "push" action switch , but Audi activates it in a " rolling motion" with a cam , this wears out the switch or cam plate ..
hellonwheels33
32
04-16-2023 07:32 AM
ZPA117
A4 (B8 Platform) Discussion
09-08-2015 11:55 AM
kjmiles
09-04-2015 04:01 AM
OSUNick
NorCal Discussion
09-02-2015 08:35 PM
