Vibrating and leaking
My car started to vibrate and when I took it home it started leaking from directly in between my tires and right behind the engine. It seemed to be yellowish brown. Any idea what is leaking?
and where about is it dripping from... if it is coming from about the center of the car under the gear shifterr, then it could easily be output shaft on the center diff.
look under the car, you will see a heat shield just behind the transmission and center diff, if it is wet and dripping chances are the center diff seal is leaking.
bballfreak
9
04-14-2019 06:59 PM
