Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
- Audi A6 C6 3.2L V6: How to Inspect and Clean Intake Valve Carbon Deposits
Step by step instructions for do-it-yourself repairs
3.2L FSI, How to inspect carbon deposit on intake valves and clean it
#71
Audishiva and boldenwell, i'll be attempting this this weekend. I have to change an injector due to error code:
I bought an injector and an injector replacing kit. I don't quite understand what you are saying about the injector teflon taping? Can you elaborate please?
Thanks!
Code:
Wednesday,08,June,2016,15:42:51:55111 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 15.7.4.1 (x64) Data version: 20160216 www.Ross-Tech.com VIN: XXXXXXXXXXXXXXXXX License Plate: Mileage: 201810km-125398mi Repair Order: Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: XXXXXXXXXXXXXXXXX Mileage: 201810km-125398miles ------------------------------------------------------------------------------- Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl Part No SW: 8E1 910 559 F HW: 8E0 907 559 J Component: 3.2l V6 FSI 0080 Revision: --H19--- Serial number: Coding: 01040109190F0120 Shop #: WSC 93009 999 04862 VCID: 3169D31DA8FE1DB6C1-8064 4 Faults Found: 004376 - Oxygen (Lambda) Sensor Heating; B1 S2 P1118 - 009 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00000100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 27 Mileage: 201623 km Time Indication: 0 Freeze Frame: RPM: 768 /min Mass Air / Rev.: 109.0 mg/str Temperature: 91.5°C Idle Voltage: 13.87 V Bin. Bits: 00000010 008304 - Intake Manifold Tuning Valve (Bank 1) P2070 - 006 - Stuck Open - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 28 Mileage: 201623 km Time Indication: 0 Freeze Frame: RPM: 768 /min Mass Air / Rev.: 114.5 mg/str Temperature: 91.5°C Idle Absolute Pres.: 340.5 mbar Speed: 0.0 km/h 000611 - Fuel Injector #1 (N30) P0263 - 007 - Contribution/Balance Fault Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 201623 km Time Indication: 0 Freeze Frame: RPM: 768 /min Mass Air / Rev.: 109.0 mg/str Temperature: 91.5°C Idle Load: 15.7 % Speed: 0.0 km/h 004407 - Fuel Trim: Bank 1 (Add) P1137 - 007 - System too Rich - MIL ON Freeze Frame: Fault Status: 10100010 Fault Priority: 6 Fault Frequency: 3 Reset counter: 40 Mileage: 201710 km Time Indication: 0 Freeze Frame: RPM: 768 /min Mass Air / Rev.: 169.0 mg/str Temperature: 91.5°C Idle Time: 1433.6 s Bin. Bits: 00000010
Thanks!
#72
Did you go through the process of walnut blasting/ cleaning the intake valves? From your fault codes it appears that the mixture is too rich which would sort of indicate that the computer can't compensate for the lack of air entering the engine. This might be caused by too much of a crud deposit blocking the intake valve area......
#74
I had to buy an entire kit of parts for each injector just to get the o-rings. A bit of a rip off by the supplier but now I have a life time supply of Teflon doughnuts.....mmmm doughnuts. Anyway, the car has been written off due to a collision with a deer. Sucks big time but she was starting to rust quite a bit. Time to move on.
#75
Injector O ring from Bosch part number provided by @4Driver4 in this post: https://www.audiworld.com/forums/a6-.../#post25010171
also, @kelisko has provided VW audi group part number WHT005422b for the same item, verified as correct for 2005 3.2FSI engine by an Audi dealership in Frankfurt.
https://www.ecstuning.com/b-genuine-...ng/wht005422b/
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
saifxnyc
9
11-30-2015 12:32 PM
ECS Tuning-Audi
Audi A3 / S3 / RS 3 MKII
09-09-2015 01:05 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
