Last edit by: IB Advertising
- Audi A6 C6 How to Replace Upper Timing Chain Tensioners<br>Step by step instructions for do-it-yourself repairs.
A6 C6 3.2 engine removal for timing chains
#11
he got it out there are no bolts coupling the engine to the transmission no torque converter in these models.. if ya got one and done this youll know .we got a new guru on the site. appreciate all the comments
#13
Thanks for excellent write up. Do you know if it's possible to remove the upper timing chain without removing the transmission or do you need to be able to remove the upper timing chains lower sprocket? Did you measure the length of your old and new chains?
#14
Rented engine hoist used bolts from bumper mounts and nutsfrom engine mounts to attach chains 2 chains placed slight pressure on chainsand removed lower bolts from engine the three Allen screw bolts then removedbell housing bolts marked location multiple lengths. Removed engine afterrealizing had to remove 1 AC line from compressor.]
Can't separate motor from gearbox
#15
Nevermind, I found a remaining bolt that I thought was out. I was feeling back there for the bolts and felt a hole which I thought meant the bolt was out, but it was further down the back of the motor. With the remaining bolt removed it came apart easily.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
ECS Tuning-Audi
09-01-2015 08:27 AM
