electric steering column adjustment failure...
just bought an 05 4.2 A6, and the column will move in/out but not up/down. Any one seen that before ? Whats the fix ?
Hi. You will need a vag com and to reset the Central Electronic module, then Measuring Blocks**and you will look for steering wheel and you gonna reset to basic settings. I don't quite remember which group was.
try this
Try this before bringing to the "AUDI TECH TEAM"
[09] - Central Electronics
Basic Setting
Steering Column Adjustment
Prerequisites:
Steering Column or the Central Electronics Control Module (J519) have been replaced.
Approach all 4 end positions (up, down, forward, back).
[Select]
[09 - Central Electronics]
[Basic Settings - 04]
Group 001
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
The adjustment should now be learned.
[Done, Go Back]
[Close Controller, Go Back - 06]
Basic Setting
Prerequisites:
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Mine would not go down with the switch, but would go down with the memory so I knew it was s switch issue. I sprayed it with compressed air then electrical contact cleaner, now it works fine.
Basic Setting
Prerequisites:
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Basic Setting
Prerequisites:
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Basic Setting
Prerequisites:
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Basic Setting
Prerequisites:
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
daleryan2430
06-10-2020 05:55 AM
smbaa6
05-28-2003 08:13 PM
