2012 A7 Prestige
Old Jan 22, 2019 | 10:14 AM
Par5ntoo's Avatar
Default 2012 A7 Prestige
New to the forums here, my A7 shredded the accessory belt. While looking at it I noticed the crank pulley assembly has lateral movement? the pulleys slide back and forth...I am not sure if it is a stock pulley (bought car used) but from my past experience pulleys are not supposed to have this much movement. Any thoughts here are greatly appreciated.
I have searched the forums for pulley failures but could not find anything talking about this.
Thanks
JW
Old Jan 22, 2019 | 05:29 PM
fkaufman's Avatar
A loose pulley will definitely put unwanted side-ward pressure on a belt, resulting shredding and eventual braking of it.
The pulley, OEM or not, should be tight on the shaft. Tightening the pulley and a new belt should solve the issue, provided the shaft is not seized up.
Old Jan 22, 2019 | 05:34 PM
Par5ntoo's Avatar
Thanks for the reply, the pulley looks like the “grooved” part of the pulley is a ring around the pulley and that’s the only part that moves back and forth? Like the balancer has a “ring” around it if that makes sense. I thought the pulley seperated
Old Jan 22, 2019 | 05:38 PM
fkaufman's Avatar
You may want to look at a car with the same belt/pulley setup and compare it to yours.
hertfordnc
Oct 4, 2013 02:13 PM
Lotus 7
Apr 27, 2010 01:36 PM
x5acob
Apr 6, 2005 11:31 AM
mofologic
Mar 4, 2004 10:36 PM
owl
Audi 100 / A6 (C4 Platform)
Mar 14, 2003 09:37 AM
