Dual Pulley Setup without CPS ??
Old Sep 2, 2017 | 07:58 AM
burlgoat53's Avatar
Default Dual Pulley Setup without CPS ??
Is anyone running the Dual Pulley setup without the CPS upgrade ?? If so, any feedback
Was told by APR that is highly recommended but not required since I only drive the car every other week and never race it so its typically a bi-weekly DD. I literally drive it like an old man but want the power available since I'm always stuck in Houston traffic. Really don't want to drop $1k on a radiator upgrade if so
Any suggestions ??
Old Sep 2, 2017 | 08:59 PM
tenspeed's Avatar
Give it a try. You won't be feeling the highest amount of advertised horsepower. You can add the additional cooling later if you want.
Old Nov 7, 2017 | 05:15 PM
bbarrow313's Avatar
the cps was by far the best upgrade i have done to my car, audi's tend to run hot in general and can handle the heat but living in the south, Atlanta, it gets really hot like in texas and the car will throttle back the power to keep from overheating and especially if you are in traffice a lot, that thing will be running way to hot but since i put the apr cps in, i can run wide freakin open all day even if its 110 degrees. it dropped my coolant temp 20 degrees and stays down, 195-200 degrees and my intake air temp is on average 40 degrees celsius and thats on a hot day. its definitely worth the money cause thats a nice car and if you are getting more power out of it then you gotta protect the motor. it is very difficult to install, about a 2 day job for a trained tech.
Old Nov 7, 2017 | 05:26 PM
burlgoat53's Avatar
Thanks for that....i finally went with the dual pulley alongside the cps an its a beast now...heat soak with out it would've been def a power killer..this car should have come with this power that this setup produces...
hova
A4 (B7 Platform) Discussion
Jun 13, 2007 07:20 AM
Black Sunshine
10
Oct 26, 2006 06:17 PM
slimj
12
Mar 18, 2006 08:36 AM
back2black
34
May 5, 2004 06:42 PM
4CE
Quattro: Turbo / Ur / Sport
Jun 30, 2003 06:48 PM
