Two other potential MMI bugs
Two other things I've notices with the A7:
- sometimes, when I go to look at online destination I've sent from Google Maps, it works fine. Others, it asks for the Audi Connect PIN to be entered. But even if I don't enter it, and sometime later try to look at them, it pulls them up without me needing to reenter the PIN. Is this a problem others are seeing?
- I know that the manual says that the car will limit the min/max volume upon restarting the car, but is the max limit really 12? Is there a way to change that?
Thanks!
eric
Thanks!
eric
Thanks!
eric
Thanks!
eric
Tel>
Settings>
Connections>
Data Connections>
"No Prompt"
I haven't figured out in Vag-Com how to avoid the warning screen when entering Nav>Info>Audi Connect for the online weather, events, news, etc. I thought I had found it in Vag but it didn't work.
Check if this is your setting:
Tel>
Settings>
Connections>
Data Connections>
"No Prompt"
Tel>
Settings>
Connections>
Data Connections>
"No Prompt"
Eric,
In regards to the first question I have this same issue and I researched it quite a bit and there does not seem to be a fix for it, this happened in my '12 A7 as well as my '13. So I just keep a stick note with the PIN in the arm rest since I am horrible at remembering numbers.
There might be a VAGCOM for this but I have not seen one.
Sully
Sully
Eric,
Sully
Sully
I, too, had the issue with having to re-enter my pin. I noticed that it takes several minutes for the car to successfully connect to Google (when the Google logo at the lower right lights up) and I wait until that connection is made before requesting information from my online account. I have not had to reenter my pin since being a little more patient.
**note** on occasion, I get an error that the connection cannot be made but that issue never asked me to reenter my pin.
geter
09-29-2015 01:39 AM
